I do not have a question, or a problem that seeks a resolution. Rather, I want to pass along a comment regarding information I learned on this forum and advice I received from members regarding the wheel alignment specs for a '64 Corvette with new radial tires and without power steering. My experience is offered to anyone that has a C2 with this configuration, and to thank those that provided great advice.
I had the suspension completely rebuilt about 500 miles ago, put on a set of American Classic radials and had it aligned to factory specs (as per the 1964 addendum to the 1963 shop manual). While the results were a huge improvement I was not completely satisfied with the handling at speeds above 45-50 mph. The car "darted" and driving required total attention.
Veteran members (too numerous to list but you -- and we -- know who they are) advised that a C2 with radials will benefit from a different suspension setup. The recommended specs are:
Front:
Caster: +1.5 degrees (but no more than +1.75 degrees)\
Rear:
Camber: negative 0.5 degrees
Toe-in: 1/32" per side; 1/16" split evenly across the thrust center line
Had my car aligned to those specs today ---- the improvement in handling is amazing - it far exceeded my expectations. And for what it is worth, the increase in difficulty of turning the steering wheel at very low speeds that many indicated would be experienced is negligible -- in my opinion, no noticeable difference. The big difference when moving along at highway speed is that steering does not require acute attention, it is a much more relaxed and pleasurable experience.
Bottom Line: The above alignment specs are highly recommended to anyone that has radials on their non power steering C2.
And thanks again to all those that recommended these settings.
Front:
Rear:
