The speedo needle is steady if I remove the cable assembly from the transmission and use a drill motor to operate the speedometer. I removed speedometer gear assembly from the transmission. I noticed if I thread the cable to the gear assembly, the gear is pushed away from the gear housing 5/16." Should I drill through the gear to remove a restriction so the excess cable has a place to extend to? Could I grind the end of the cable without having the strands unravel? Buy another cable?
Thanks, Ken
Thanks, Ken
