1988 Spare Tire Rim - NCRS Discussion Boards
1988 Spare Tire Rim
  • John G.
    • September 24, 2013
    • 245
    1988 Spare Tire Rim
    This is my '88 Anniversary spare tire (both sides) and tub. I'm planning on cleaning everything before flight judging being careful to not change or remove any of the markings/grease pencils/etc but should I:
    Leave the rim as is or paint (if so what paint)?
    On the tire should I use a tire shine product or just clean it with soap and water?
    Any other helpful suggestions to minimize my points deductions?
    88-corvette-spare-tire-carrier.jpg88-corvette-spare-tire-face.jpg88-corvette-spare-tire-back-and-jack.jpg
  • Patrick N.
    • March 10, 2008
    • 951
    Re: 1988 Spare Tire Rim
    Hi John, for the tire, use soap and water to get most to the dirt off then Bleach White tire spray to get the brownish look out of your tire.
    I do not know what paint to use on the rim. maybe SEMS? Depending on the condition of the rest of the car, you could just leave well enough alone.
    Good luck
    pat
    • David H.
      • June 30, 2001
      • 1485
      Carefully clean (don't destroy crayon marks, etc) with soap and water. With tire shine/repaint/etc you trade originality points for condition points. IMO you are better off with original surfaces (finish) and take any hit on condition. Tire shine/repaint by itself will generate a 20% originality deduction for FINISH. There are a total of 80 points out of 4500 assigned to cleanliness so it is not a cleaning contest. The judge needs to be able to read stampings etc so they should be ledgible. But don't clean so much you loose ink stamps, paper tags, etc that might still remain.
      Also be careful with the black plastic bag containing the jack. Those bags are fragile. If you were to do anything, a gentle wipe with a damp cloth. Same as with the spare tire, just a gentle wipe with a damp rag to get the dust off. Surfaces "goo'd" up with armor all etc will all get originality deductions for finish. Your engine stamp pad should be clean, but no harsh abrasives/scapers/etc.
      • John G.
        • 245
        Thanks - I'll do no paint, no tire shine, just carefully clean with soap, water and a soft brush. I know from my '61 which has a number of original marks to never touch these things. Onward to more things to fix such as the 5 light bulbs that I've already replaced (and I only knew about 2). Emergency brake which hasn't been used in 15 years is part of today's efforts.
        • Patrick N.
          • March 10, 2008
          • 951
          If the soap and water does not get all the dirt, I do recommend Bleche-White as part of the tire cleaning. if you have not used it, it is not a tire shine, it will pull all that "brown" out of the tire and restore to a more natural black.
          • John G.
            • 245
            Thanks for the suggestion. I haven't used this product for several years. Have had good luck here in SW FL using Simple Green on both WW and BW tires. It look good enough after a cleaning to put it back in the tub and call it good.
            • Ed N.
              • May 16, 2010
              • 990
              Once my spare tire is cleaned, I wipe it down with this product.
              Here's what the final product looks like. Nice natural finish.
              Ed Nieves
              NCRS #51799
              • John G.
                • 245
                Is it a correct assumption that this is a zero point deduction product? Do you just carefully go around the yellow crayon marks on the tire or can this product go over them?
                • Ed N.
                  • May 16, 2010
                  • 990
                  John, if your question is directed at me, I have never received a deduction for using this product. I have applied it on my yellow markings with a disposable paint brush and it did not remove it. Of course, this is my experience and I can't guarantee you the same results. If you want, after applying it with a brush you can wipe it down with a microfiber rag. It does not leave a shinny gloss when dried. I would clean with another product and apply #40 as a finish to bring back the black.
                  Ed Nieves
                  NCRS #51799
                  • John G.
                    • 245
                    I'll go get some and give it a try. I think it's best to get every point that one can reasonably afford and has time for. Now if I can just find some Guide headlights for my '88 I'll be good.
                    • John G.
                      • 245
                      I applied it and then used an old towel to remove/buff it. Looks like a good representation of what it likely looked like 28 years ago.
                      Good suggestion Ed.
                      • Ed N.
                        • May 16, 2010
                        • 990
                        Good suggestion Ed.
                        [ATTACH=CONFIG]70148[/ATTACH]
                        John, I would hit again. It only gets better. Brush it on and let soak in. Oh, check out this link:
                        Ed Nieves
                        NCRS #51799
