'63 SWC w/ A/C - NCRS Discussion Boards
'63 SWC w/ A/C
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11302
    #31
    Re: '63 SWC w/ A/C
    Originally posted by Dale Coleman (60823)
    As I continue my frame off restoration of my '63 SWC, I notice that in addition to the build number (202) which is hand written on numerous locations including the fire wall, fiberglass just ahead of rear wheels and the inside of both door panels, there are also the letters "EXX" hand written as well. This seems a little unusual. Does anybody out there have any idea what this might mean? My car's build date is 4/11/63 if that has any bearing on anything. I appreciate any input on this. Thank you.
    202 is the Job Number, typically 1 to 500 then repeat. This was used to help track parts inventory etc.
    I'm certain Harry and others will chime in, but I'm curious. Where exactly is "EXX" hand written?
    My WAG on the EXX ? .... EXperimental "X".
    • David G.
      • May 31, 1980
      • 274
      #32
      Re: '63 SWC w/ A/C
      Harry, Regarding the 64 style compressor mount. Years ago I have seen several unrestored
      63 C60 cars with 64 style compressor brackets. I believe that they were upgraded when the stamped
      brackets cracked. As you know, the 63 style brackets were
      rather delicate, which is likely the reason that they were strengthened for 64 to 67.
      Dave
      • Dale C.
        • January 12, 2015
        • 18
        #33
        Re: '63 SWC w/ A/C
        Thanks for the reply. "EXX" is hand written right next to "202" on the inside of both door panels.
        • Russ S.
          • April 30, 1982
          • 2161
          #34
          Re: '63 SWC w/ A/C
          Loren, How would this documented Oct 62 order indicate there were none built before it?
          Originally posted by Loren Lundberg (912)
          How long have you owned the car & how many owners/history do you think you have? As of now, the prevailing information would indicate that your car is about 1500 units early, based on a documented Oct '62 order for an A/C car that is/was still in the hands of the original owner.
