On a non air conditioned car can a shut off valve be placed in the hose off the water pump? The reason is constant heat with controls in car in the off position.
C3 1977 Heater Hose routing
Re: C3 1977 Heater Hose routing
Sure. That's a common practice for drivers without a factory installed valve. Some use two valves, one for each hose.
I completely disconnected the heater core, which eliminates hot coolant in the cabin altogether. Of course it's more work to restore heater function, but that feature for a big block driven in Texas is superfluous.Mark Edmondson
Dallas, Texas
Texas Chapter
1993 Coupe, 40th Anniversary, 6-speed, PEG 1, FX3, CD, Bronze Top- Top
