Gas tank on '70 makes "woosh" sound when removing cap. Normal? - NCRS Discussion Boards
  • Mark E.
    • April 1, 1993
    • 4498
    My '70's fuel tank made a "woosh" sound as the gas cap was removed to refuel. Is this normal?
    This was the first refuel since I replaced a locking, vented cap (which was on the car when purchased) with a STANT 10852 sealed cap. The tank never made a sound with the old vented cap. The Stant was recommended by Joe Lucia on the forum as a duplicate of the original (and visually, it looks like an original '70 cap, as per the JG).
    Does the "woosh" mean the gas tank's vent line is blocked? This car does not have NA9 (evaporative canister system).
    Mark Edmondson
    Dallas, Texas
    Texas Chapter
  • Mike F.
    • April 25, 2011
    • 668
    Re: Gas tank on '70 makes "woosh" sound when removing cap. Normal?
    Hi Mark,
    My 70 never makes a "woosh" and I use the original cap.
      • 15573
      Hi Mark,
      I believe mine did when I used the original cap. I haven't used it (the original cap) for years now, however.
      • Mark E.
        • April 1, 1993
        • 4498
        Thanks Mike.
        Maybe my 70's gas tank vent is not working properly?
        It was good to see you at the Chapter meet!
        Mark Edmondson
        Dallas, Texas
        Texas Chapter
        • Gary C.
          • May 28, 2012
          • 66
          Mark,
          The vented cap vents the tank thru the cap. There are no other openings to the atmosphere in the rest of the fuel tank unless you have the evaporative control system. If you install non-vented cap, no vent and woosh sound is air rushing into tank when you open it since fuel was extracted to the engine and no vent to allow air into tank to replace the fuel that left.
          On 70 NA9 and 71 and later , the ECS uses non-vented cap and vents fuel tank thru the canister to the engine thereby providing vent to the fuel tank and keep fuel vapors from getting into the atmosphere.
          Gary
            • 3415
            Hi Gary,
            I thought that 70 model year gas tanks without EEC provisions still had the 'button' relief valve located near the provision for the filler neck?
            Regards'
            • Bill L.
              • February 1, 2004
              • 1403
              I can confirm that 70 original tanks do indeed have the relief valve.
              Bill
              Hi Gary,
              Regards'
              • Mark E.
                • April 1, 1993
                • 4498
                Originally posted by Bill Lennox (41387)
                I can confirm that 70 original tanks do indeed have the relief valve. Bill
                How does it work? Does it open when tank vacuum reaches a certain level?
                Is there a way to test it? I imagine it's probably near impossible to reach or even see it with the tank installed.
                Mark Edmondson
                Dallas, Texas
                Texas Chapter
                  • 15610
                  Those valves, whether built into the cap or remote are typically vacuum/pressure relief, and open at something like +/- 1-2 psi, but I've never seen a spec for those early pressure relief valves used on Corvettes. Check the CSM for possible information.
                  It's typical to hear that "whooshing" sound on modern cars when refueling as consumption of fuel tends to develop vacuum in the tank, but sitting on a hot day can cause the pressure to rise above ambient.
                  • Mark E.
                    • April 1, 1993
                    • 4498
                    It's typical to hear that "whooshing" sound on modern cars when refueling as consumption of fuel tends to develop vacuum in the tank, but sitting on a hot day can cause the pressure to rise above ambient.Duke
                    I expect the woosh on modern cars with a sealed system. I'm wondering if a woosh with a '70 vented system means the vent isn't working.
                    Mark Edmondson
                    Dallas, Texas
                    Texas Chapter
                      • 15573
                      I know my gas tank has that vent valve, and as I said earlier I get the "whosh" when I use the original SEALED cap. I am petty sure it is the way 1970s are supposed to work.
                        • 3415
                        Hi,
                        Actually the button valve is near enough to the filler neck that if you flatten the rubber filler/drain boot you can see and reach it, and if your hand is small enough you can reach it's other end through the filler neck.
                        You can test it's operation that way, but of course have no sense of at what pressure it opens.
                        • Mark E.
                          • April 1, 1993
                          • 4498
                          So Mike F. says his '70 L46 doesn't woosh, while Terry believes his '70 LT-1 did woosh when it had the original sealed cap installed.
                          Maybe the woosh occurs if there's vacuum but not enough to open the vent valve?
                          Mark Edmondson
                          Dallas, Texas
                          Texas Chapter
                          • Mark E.
                            • April 1, 1993
                            • 4498
                            ... You can test its operation that way, but of course have no sense of at what pressure it opens.
                            Alan, how are you suggesting the vent valve be tested? By pushing it back and forth from each end?
                            Mark Edmondson
                            Dallas, Texas
                            Texas Chapter
                            • Bill L.
                              • February 1, 2004
                              • 1403
                              Hi Mark,
                              Just a thought. L46 has a return line and LT1 does not. I do not know if this makes a difference or explains why Terry's LT1 may have made a woosh when removing the gas cap and the L46 does not. Mine is an L46 and I have not heard a woosh.
                              Bill
