Smelly 57 - NCRS Discussion Boards
Smelly 57
  • Jack A.
    • March 1, 2001
    • 129
    Smelly 57
    Hello,
    I have a 57 that has been recently finished. The problem is that it smells of gas when I get into it. It is a resto. mod with a LS motor and drive drain. It retains the original gas tank, gas filler, and gas lines. There are no obvious leaks anywhere. Any ideas as to where the odor could be coming from? Is it a 57 issue or experienced by others? It is very strong and so far the origin undetected.
    I also have a CI 61 Fuelie restored original with similar gas retention and conveyance system but without the problem.
    Jack
  • David S.
    • December 1, 1982
    • 310
    Re: Smelly 57
    Jack if you have an original tank determine if it is a vented or non-vented tank. Most likely it is a vented tank so be sure that it has been vented to the fuel fill area and that your are using a non vented gas cap.
    Dave
    • Tom R.
      • June 21, 2015
      • 2
      Re: Smelly 57
      Here is a good technical paper that may help you out. I found the source of the gas odor in my '58 to be a cracked rubber filler neck.
      • Tom R.
        • June 21, 2015
        • 2
        Re: Smelly 57
          Re: Smelly 57
          Originally posted by Jack Alexander (35730)
          Hello,
          Jack
          Jack -
          Check out this article on how to diagnose and cure the "C-1 Gas Smell":
          C1 Gas Smell Fix -sm.pdf
