I reinstalled the gauge cluster in my 67 (AC, power glide, 327, regular steering column) over the weekend, after having it worked on by Corvette Specialties. When removing and reinstalling the cluster, I disconnected the steering column from the rag joint by removing the star headed bolt in the clamp and pulled the column back from the dash so that it would drop out of the way. Didn't pull the column completely out of the car. After I got the cluster out, I put the steering column back in the rag joint clamp and reinserted the three mounting bolts under the dash so the column wasnt hanging unsupported while waiting since March for the cluster to come back from Corvette Specialties.
So now it's been so long, that may be I forgot something. But it seems to me that before even with the steering wheel off and the horn contact ring not yet installed, shouldn't the horn sound when I push the plunger down (I guess that's the horn switch), or am I imagining the horn works that way? Seems like it did. But now, the horn does not sound. Haven't tried it yet with the steering wheel reinstalled (by the way, I didn't pull the hub, just unscrewed the 6 screws that holds the steering wheel on and the 3 screws that hold the horn contact ring).
If the horn should sound but mine isn't, my next question is figuring out the problem and fixing it.
I looked up horn trouble at page 12-15 of the 1963 Corvette Shop manual and the steps are clear enough except for one minor detail: I have no idea where to look under the hood for the horn relay nor an idea of what the horn relay looks like. So that's my other question--where would the horn relay be on a 67 with AC, power glide and 327?
Lastly any suggestions on fixing it once I figure out where my problem is, and if it is in fact wiring what's the way of fixing it--I'm betting something may have gotten pinched/shorted in the column when pulling it out, moving it up and down, etc...while pulling and reinstalling the gauge cluster. And oh yes, horn worked fine before, and the battery was disconnected the entire time. First thing I did in fact before taking the driver's seat out, removing the steering wheel and unbolting the steering column.
On the bright side, the restored cluster looks great, I now know where each cluster bulb goes by heart, and my hands will heal from the 1,000 little nicks and scraps in no time. Thanks all, for the help.
