1954 Engine and Transmission Numbers - NCRS Discussion Boards
  • Kim F.
    • July 15, 2009
    • 80
    These are the numbers that are on the engine and transmission of my 1954 Corvette. Can someone tell me where the information for these numbers is located?
    Thank you
  • Tim E.
    • April 1, 1993
    • 360
    Re: 1954 Engine and Transmission Numbers
    Kim - Here's what it looks like you've got:
    Transmission main case: 3784867 is a Powerglide cast in the foundry on F151 which is June 15, 1961.
    Engine stamping: F609B Flint block, assembled on 609 which is June 9, 1958, suffix code B is a 235 CID, 145 HP, 1 BBL Carb, with Powerglide. Below the engine stamping is the date code of F58 which is June 5, 1958.
    Cylinder Head: 3836848 is the passenger car cylinder head. The date code is under the valve cover.
    For original 1954 Corvettes...
    Engine block: 3835911 with an assembly stamp of nnnnnnnF54YG where nnnnnnn is a seven digit sequence number (not a date).
    Cylinder Head: 3836241.
    Tim
    • Kim F.
      • July 15, 2009
      • 80
      Tim,
      Thank you for your help. I am selling the car and had gotten confusing dates for the numbers.
      Kim
