Coil Bracket for a 73 Corvette? - NCRS Discussion Boards
  • Jimmy P.
    • June 24, 2014
    • 1695
    Is this coil bracket correct for a Corvette? Specifically my 73?
    Thanks!
    Jimmy
    1973 Convertible
    L48,M20,N40
    Mille Miglia Red/Oxblood
  • Harmon C.
    • August 31, 1994
    • 3228
    Re: Coil Bracket for a 73 Corvette?
    The bracket looks good but is missing the special screw.
    Lyle
    • Jimmy P.
      • June 24, 2014
      • 1695
      Thanks Lyle,
      I have the screw. What should the mounting bracket bolt heads have on them, in order to be NCRS correct? Thanks Russ S. Got your email with bolt pic.
      Jimmy
      1973 Convertible
      L48,M20,N40
      • John S.
        • June 15, 2015
        • 505
        Jim, looks the same as mine and just about as crusty. Let me know if you have any luck cleaning it up. Here's one of the shots I sent you on the mounting bolt heads, I believe mine are original.
        Good luck,
        John
        1973 L82 M21 4 Speed, very original and well documented driver/survivor
        NW Chapter Member, 2016 Bend Regional Top Flight
        73/74 TIM&JG 3rd Edition Revision Team Member
        • Don L.
          • August 31, 2005
          • 1005
          Hi Jim. Hope you are well.
          IIRC, one coil mounting bracket bolt was installed at Flint (small blocks) and one at St. Louis. I suppose this means there'd be a possibility that head marks on these 2 bolts could be different. Additionally, in so much as one bolt was installed at the engine plant, it would be painted, whereas the bolt that was installed at the assembly plant would not be painted. The painted one was in the inboard position, matching up with the coil bracket's slotted "ear". The bolt that was installed at St. Louis matches up with the fixed hole in the outboard "ear."
          Let's let others either correct me or confirm as correct.
          Hope this helps!
          Don Lowe
          NCRS #44382
          Carolinas Chapter
            • 15573
            Hope this helps!
            That's the way it was on C3s up to 1972.
            • Don L.
              • August 31, 2005
              • 1005
              Thanks Terry. I knew my '72 was that way. I don't have a '73 AIM or judging guide. I don't know '73 as much as I should. Learned this today.
              How WAS the '73 set up?
              Don Lowe
              NCRS #44382
              Carolinas Chapter
              • Jimmy P.
                • June 24, 2014
                • 1695
                Hi Don,
                The 73-74 JG makes no mention of one of the bolts being engine orange. This surprises me somewhat because a lot of the 73-74 TIM&JG is a 72 carryover on many items, especially on the earlier cars. But nice to know the JG is correct in reference to these items. Thank you also Terry for the information. John Sigmund who posted the pics of his bolts above, has a pretty original Dec. 73 and his bolts are both natural. I've asked a couple other original 73 owners to see what they have on their cars. Haven't heard back. However this is still very interesting as far as documentation goes. Why all of a sudden would GM start doing it differently on the 73 SB's. The brackets appear to be the same.
                Jim
                Jimmy
                1973 Convertible
                L48,M20,N40
                • Russ S.
                  • April 30, 1982
                  • 2161
                  Neither of the bolts on either of my 73s have any paint on them. Also they appear to be cad plated.
                    • 11608
                    Note the "up to" 1972.
                    In 72 the procedure changed, and both are plated (i.e. unpainted). I believe it's dull zinc; as John Hinckley has said GM wouldn't spend the $ on cadmium for this type of part.
                    Patrick
                      • 15573
                      Originally posted by Jimmy Patitucci (60161)
                      Hi Don,
                      Jim
                      I can't explain why they might have changed some of these assembly procedures, but they sometimes did. Try to track the installation of the fitting into the water pump for the heater hose. That was installed at the engine assembly plant, then at St Louis (different fitting for AC, and non-AC) then back to the engine plant with the same fitting for all. It was a hot mess. I am sure that someplace someone had to justify these changes, but most of that documentation is long gone.
                      • John S.
                        • June 15, 2015
                        • 505
                        Very interesting and I do follow the thought process that the first bolt (slotted position) could have been installed prior to engine paint. That would also explain the possibility of different head types.
                        Just gave my '73 another close look, no evidence of paint on either bolt, nothing even in the inner portions of the serrated washers. Both of my bolts match, plating is a good question. They are dull zinc, if they were plated a different color, that plating is completely gone and most of the plated parts on my car show some evidence of the original plating.
                        I'll shoot an email to one of our Chapter members, he is the original owner of his '73 and our cars were built within a month of each other, his being a Jan '73 car and see what he says. Possibly another good update to the '73-'74 JG.
                        • Russ S.
                          • April 30, 1982
                          • 2161
                          I removed one of the bolts on one of the cars and the threaded portion was very nice and shiney as if plated. and none of them have any rust indicating some sort of plating.
                          • Ralph S.
                            • February 1, 1985
                            • 935
                            The bolts on my 73 are not painted.The bolt closest to the valve cover has a letter L , the other one has a check mark like the one in the other posting. Who would ever notice something like that?
                            • Jimmy P.
                              • June 24, 2014
                              • 1695
                              Hey Ralph,
                              Sorry I wasn't home to get your call. I enjoy talking with you about our 73's. Thank you for responding here. It is interesting that your bolts don't have the same head markings, especially since they would have been installed at the same time unlike what Don reported in the earlier post from his 72, which had one put on at Flint and the other in St Louis.
                              I guess only us crazy corvette restoration guys would notice something like that? This kind of research does uncover many nuances that ocurred at GM when our cars were built. But, none the less it is very interesting and well worth the documentation. At least for me anyway!
                              Thanks again to all who have responded here.
                              I hope everyone has a safe Memorial Day Weekend. Thank you to all who have served, and to all who are serving our country now!!
                              Jimmy
                              Jimmy
                              1973 Convertible
                              L48,M20,N40
