65 big block hood alignment - NCRS Discussion Boards
  • Anthony C.
    • May 25, 2016
    • 10
    I have a '65 big block coupe, is there a way to lower the front edge of the hood , there are no shims under the hinges to remove to lower the hood?
  • Domenic T.
    • January 29, 2010
    • 2452
    Re: 65 big block hood alignment
    Anthony,
    I slid my hinges around a bit and got some results but found that raising the nose with the braces will help.
    Dom
    • Stewart L.
      • March 1, 1980
      • 351
      There is probably an underlying problem such as the frame rail misaligned or header bar bent causing the problem. You can try a couple of things that may help. As previously mentioned, you can loosen the support rod from the radiator support to the headlight bracket and pull the nose up a bit. You may need to enlarge the mounting hole on the bracket to allow the nose to come up. You could also put a shim under the lower rear hood hinge bolt and this will tilt the front of the hood down.
      • Anthony C.
        • May 25, 2016
        • 10
        Thanks, for your help, I'll try it
