I have several air cleaner assemblies and when I was replacing the one on my survivor 1967 L71 I noticed that they were slightly different. Primarily where the breather hose enters the air cleaner base. I've attached pictures of the two side by side. Which one is correct for a 1967? I hope its the one on the right with both carburetor attachment tabs.
1967 427 Air Cleaner Base 400 / 435
Re: 1967 427 Air Cleaner Base 400 / 435
Rob, Try to take some closeup photos of the 2 tabs and their spot welds on each base. On the one that is missing the tabs, the welds will probably still be there.
I believe originals were very small spot welds.
Rich- Top
Here are close up pictures of the area where the vent tube extends into the air cleaner base. Which one is correct for a '67 or are both correct?Attached Files- Top
Here is another picture of the two different 427 air cleaner bases side by side. Any idea what year each one is for?Attached Files- Top
Here's pics of the nozzle and weld details on the brackets on my late '69 tripower L68 setup (carb dates 2x951, center 981).
(excuse the cat dander
- Top
