1966 Head Identification via Oil Cap - NCRS Discussion Boards
  • Erv M.
    • February 21, 2007
    • 445
    Can you see the head part number via the oil cap or is the valve cover required to be removed?
    Trying to understand if a car I am looking at has oval or square heads.
  • R N.
    • May 31, 2002
    • 640
    Re: 1966 Head Identification via Oil Cap
    I don't believe you will see what you want without removing the valve cover.
    1966 - 425 HP with have rectangular ports and the 390 HP has oval ports. Attached is of my L72 head - casting number ending 858, not sure the casting number for the 390 HP
    '66 heads will have the machined area and a small tapped thread for holding the spark plug heat shield.
