Can someone help me with finding yellow brushable w/s adhesive other than 3m. There use to be a guy in the Driveline that advertised he had such a product but I have never used it or have a contact # for him ?
Yellow weather strip glue
Re: Yellow weather strip glue
Jeff------
What's wrong with the 3M product?
By the way, the original adhesive was NOT clear when originally applied. It was yellow and became yellowish-brown with age.In Appreciation of John Hinckley- Top
Jeff------
I have owned my 1969 since new. I can tell you, for certain, that there was obvious yellow adhesive present in areas adjoining weatherstrip. It was very obvious and I remember it quite well.
The adhesive used for all Corvette weatherstripping was "neoprene solvent cement". 3M weatherstrip cement is a "neoprene solvent cement". I would not be the least surprised if 3M was the supplier of the cement originally used by GM.
By the way, if you wish to use the adhesive in a way that none is visible when the weatherstrip is installed (as you presume original GM quality control would have insisted on), then it does not matter what color adhesive you use----no one will see it, anyway.In Appreciation of John Hinckley- Top
Hello, have found "Goodyear Pliobond" sold at most better hardware stores to be a good product. it comes in a 6oz ??? bottle and it has an applicator brush. i have used it for over 30 years and it will withstand years of use without separating from either of the attaching surfaces. any unused remainder will store for a period of up to 6 months but i would discard it after kept any longer. inexpensive and excellent adhesive quality.yellowish/tan/brown in color.- Top
Wellbond Contact Cement - judges love it - works great - buy at Ace Hardware1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
1957 Corvette - FI 3 sp - Black and Silver- Top
I second the Pliobond glue. Used on a '65 and it has a carmel color. I found mine at Aircraft Spruce Air & Specialty Co. www.aircraftspruce.com.
James West
I've also used Pliobond. Of the products I've used, in my opinion, it comes closest to resembling the look of the original adhesive. That and Wellbond Contact Cement, which I also like can be purchased at Ace Hardware. If you're into fly fishing, Pliobond serves a dual purpose and can be used on your line knots.- Top
I have used Al Knock brushable contact adhesive. It is light yellow in an Al Knoch labeled can, but is made by Weldwood. It is not as yellow as the 3M stuff in the tube.Don Harris
Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)- Top
