Warning: Undefined array key 24282 in .../vb/library/content.php on line 3508 Warning: Trying to access array offset on value of type null in .../vb/library/content.php on line 3510 Warning: Trying to access array offset on value of type null in .../vb/user.php on line 737 Warning: Undefined array key "online" in .../vb/library/content.php on line 3522 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Undefined array key "birthday_search" in .../vb/api/user.php on line 165 Warning: Undefined array key "joindate" in .../vb/api/user.php on line 182 Warning: Undefined array key "posts" in .../vb/api/user.php on line 183 Warning: Undefined array key "posts" in .../vb/api/user.php on line 189 Warning: Undefined array key "userid" in .../vb/api/user.php on line 6480 Warning: Undefined array key "userid" in .../vb/api/user.php on line 204 Warning: Undefined array key "privacy_options" in .../vb/api/user.php on line 246 Warning: Undefined array key "userid" in .../vb/library/user.php on line 5342 Warning: Undefined array key "userid" in .../vb/library/user.php on line 1594 Warning: Undefined array key "lastactivity" in .../vb/library/user.php on line 1610 Yellow weather strip glue - NCRS Discussion Boards
  • Gerald C.
    • June 30, 1987
    • 1273
    Re: Yellow weather strip glue
    James,
    I went on the Aircraftspruce website and there are a few choices of product. Which product did you use?
    Jerry
    • Danny P.
      • Today
      I remember Ford dealer were caring a can of yellow glue with a twist off top with a brush used it many times works great with brush
      • Frank T.
        Infrequent User
        • March 20, 2013
        • 26
        #18
        Barry Blocher has the rite glue goes on clear than darkens phone (260 982 4991 )
        • Dick W.
          • 10483
          #19
          Dap Weldwood is very close to what you see on unrestored cars. Just get an acid brush and spread to your lil ole pea pickin' hearts is content
          Dick Whittington
          • Paul S.
            • June 30, 1982
            • 354
            #20
            Barry stuff is the best
            • James W.
              • December 1, 1990
              • 2640
              #21
              Originally posted by Gerald Coia (11656)
              James,
              Jerry
              Jerry,
              I ordered the Pliobond 20 in the one pint can. See the link below.
              James
              • Ron G.
                • December 1, 1984
                • 865
                #22
                I have had the opportunity many years ago to obtain the "real stuff" from a supplier to GM. I believe that it was yellowish, but not the yellow that is often seen on restorations today. It was more of a yellowish/brown in color. The best way that I can describe it is that it looks like Gulden's mustard. Like many of you, I remember these cars fairly vividly, and they always had that yellowish/brownish color. Definitely not pure yellow. I do agree with Joe L. that it probably did turn darker with age.
                "SOLID LIFTERS MATTER"
                • Mike M.
                  • May 31, 1974
                  • 8365
                  #23
                  I agree with Ron. gulden mustard, not French's. mike
                  • Edward B.
                    • January 1, 1988
                    • 537
                    #24
                    May not satisfy the NCRS color standard, but 3M's yellow death has worked fairly well for me for over 50 years.
