63 coupe outer door window seals hit glass when in down position. - NCRS Discussion Boards
  • Chester C.
    • May 29, 2013
    • 154
    The rubber seals when installed rub against the door glass when glass is going in the down position. Looked at the technical manual and can not find a way to adjust where they will not hit. I know they are suppose to hit but it's keeping the glass from going up it interferes to much. raising up.Anyone have any ideals.
  • Joe R.
    • July 31, 1976
    • 4547
    Re: 63 coupe outer door window seals hit glass when in down position.
    The outer door seals only hit the stainless glass frame when the door glass is in the up and closed position. Either you have incorrect seals or they are installed wrong. Some pictures would be helpful.
    JR
    • Richard M.
      Super Moderator
      • August 31, 1988
      • 11302
      JR
      JR, Is it possible that his rear channels are adjusted too far outward?
      Rich
      • Joe R.
        • July 31, 1976
        • 4547
        Rich,
        Anything is possible but without pictures it is just shooting in the dark.
        JR
