After complete rebuild of the front and rear suspension the following problems have arisen:
The rebuild was accomplished by a reputable shop as was the alignment (two independent shops).
The alignment tech. stated the car aligned easily, no issues. The car is aligned to these specs;
Front:
Rear:
The rebuild shop is very willing to investigate the problems however I would very much appreciate technical input before I return the car. (I hope this will save some trouble shooting time).
None of these issues existed prior to the work. The work was done to correct deteriorated bushings, old bearings, and general aging related issues of many components.
For reference the car is a factory big block with power steering. New A-arms (with pre-installed bushings and ball joints), new steering box, new wheel bearings etc. have all been installed. The power steering valve and ram was rebuilt (was leaking) along with all new hoses etc. A new dual master was installed with all new brakelines also.
The rear suspension has all new bushings, bearings, u-joins, brake lines, S.S. e-brake parts etc. installed. The car has a the factory rear spring with factory strut rods and factory sway bars front and back. Replaced bushings were rubber type except the sway bars now have poly bushings.
This performance (or lack thereof) is bit difficult to describe, I hope I have been clear enough that someone can recognize this situation.
I very much appreciate all suggestions.
Thanks in advance for all assistance!
Front:
Rear:
