1963 Headlight Bucket Stop - NCRS Discussion Boards
  • Lawrence E.
    • November 7, 2013
    • 23
    Hello
    When I close my headlights, the passenger side Headlight Bucket is not flush, it's slightly raised above. What is the easiest way to adjust the Headlight Bucket Stop?
    thanks, Larry
  • Loren L.
    • April 30, 1976
    • 4104
    Re: 1963 Headlight Bucket Stop
    Easiest way is to read the Service Manual.
      • 6940
      Larry, There is no easy way, you'll be looking at everything upside down from under the front of hood area, there is a (Y-shaped) arm that has adjustments for full open and full close, I find working with a mirror, and someone to rotate the headlight doors to a partly open position to get a wrench or socket on the adjusters to turn. I think it will take some studying of motors and which adjuster you need to adjust. Good Luck
