68 Wiper Door Woes - NCRS Discussion Boards
68 Wiper Door Woes
  • Jeff P.
    • 797
    68 Wiper Door Woes
    Hello all. I believe I've read everyone's troubles regarding the wiper door. The service manual would be great if I had to rebuild the wiper motor. Not now anyway. Owning a 68 there are some differences. When I turn on the battery the clicking noise is coming from behind the override light that is now on. I do not hear anything coming from behind the tack. With car running I pull the light switch the lights come up and on. I push the knob in,they go down. Under the steering wheel I pull down the light switch the lights pop up.
    push it in they go down. By the way when I start the car the wiper door is down and stays down. Now I pull down the right switch to open the wiper door nothing. I turn the override knob nothing. I turn on the wiper switch up top nothing. I did look at the fuse and it looked good. I pulled the front actuator hose and I was getting suction while the motor was running. Any help or comment would be greatly appreciated. Thanks, Jeff
    68 L79 Convertible: Triple Black: Work In Progress, Body off. Now on!
    2014 Arctic White Z51 Vert. (Wifes)
