I'm questioning whether I have the correct parts on my unit.
On John DeGregory's catalog he shows an earlier two tube unit with a screw with a triangle head stamp. Some vendors show this same stamp on a blunt tip screw in 63 clamp kits. I did not find a 64/64 kit, just clamps. My screw is a 1/4 hex head sheet metal screw with a pointed tip and a slot which causes me to believe it may be wrong. A pointed tip screw with no slot and a triangle stamp is used to secure the blower motor on some cars so I was wondering what was right on the front of the FI unit. Any help would be appreciated.
For the clamp the pic below is what is currently being sold as a repro. On mine the two mounting ears are on a radial line of the clamp circle rather than offset as shown although one has a nice die made bend and the other more rounded in the bend. I'm suspecting that mine got that way by being assembled "backwards". The balance tube and clamp circle will fit under the mounting boss so the clamp could simply be deformed; however, in searching for pics of 7380 single tube units I see a lot of them that appear to have this confiuguration. What is the right clamp and mounting?
