1967 door sill attachment dilemma - NCRS Discussion Boards
  • R N.
    • May 31, 2002
    • 640
  • Scott S.
    • March 1, 1979
    • 747
    Re: 1967 door sill attachment dilemma
    Kurt. The plastic wall plugs will work well, they come in various sizes yellow, Blue and red.
    Scott
    • Jim S.
      • March 13, 2013
      • 360
      One of these should work
      • Bill L.
        • April 1, 1985
        • 349
        Kurt:
        While you are at it be sure to use the screws with the smaller heads. They should fit flush in the holes----I took a small deduction for the larger screws the last time my '67 was judged.
        Regards
        Bill
        • Leif A.
          • August 31, 1997
          • 3607
          Originally posted by Bill Lucia (8620)
          Kurt:
          Regards
          Bill
          Bill,
          Would you say these, then, are correct? No hijack intended.
          Leif
          • Dan A.
            • May 31, 1974
            • 1074
            If you would prefer a more automotive solution please view this link as an example of barrel nuts. Available from many sources. A Google search may help. They work well, are barely detectable and don't look so much like Bubba was there.
            • Bill L.
              • April 1, 1985
              • 349
              Originally posted by Leif Anderson (29632)
              Bill,
              It's hard to tell from your photo.... but the screws should be pretty much flush with the top surface of the panel --- not sticking up ---
              They should look like this....
              • Thomas S.
                • February 7, 2016
                • 603
                You could also use internal threaded pop-rivets. The are installed the same way as a standard pop-rivet but when the rod breaks off you have standard female threads to use. You would install them below the trim and the use an appropriate size and thread phillips head screw to match the thread of the pop-rivet.
                fast forward to about the halfway point
                67 427/400 Lynndale Blue Corvette https://online.flippingbook.com/view/750924569
