T-10 Sideplate torque - NCRS Discussion Boards
  • Bob S.
    • August 12, 2007
    • 185
    Can someone give me the torque specs for the 9 side plate bolts on a BW T-10. All I can find in the ST-12 and other GM pubs is "tighten evenly".
    Thanks, Sully
    Re: T-10 Sideplate torque
    Thanks, Sully
    Bob------
    The Muncie side cover bolts are 20 lb/ft (which seems like a lot to me but that's what GM says). In any event, I would expect the T-10 is the same.
    • Bob S.
      • August 12, 2007
      • 185
      Thanks Joe. It is a steel housing so hopefully the threads will take it.
        Bob------
        The cast iron main case should be better able to take the torque than the aluminum housing Muncie. Also, the GM Saginaw 4 speed which used a cast iron main case and a cast iron side cover had side cover bolt torque specs of 22 lb/ft.
        • David B.
          • March 1, 1980
          • 687
          The T-10 Warner Gear blueprint for '57 4 spd assembly #3743441 specifys #179816 Cover and Clutch gear bearing retainer bolts 15 to 20 ft. lbs.
