Can't See My Baby By The Dash Board Lights (1966 C2) - NCRS Discussion Boards
  • Edmund C.
    • April 14, 2015
    • 232
    Guys: I just went to an impromptu party with the Bride and drove home afterwards in the dark. Great time and the Vette was a champ, yet, the dash board lights were out despite my manipulation of the switch. Is it a simple fuse issue or something else? Any guidance appreciated. Have a great weekend. Best, Ned
  • Don H.
    • December 1, 1981
    • 1482
    Re: Can't See My Baby By The Dash Board Lights (1966 C2)
    I would start simple - check the fuses and see what else is on that circuit. The switch is obviously another possibility but I can't tell you how to check it simply. Good luck, Don H.
    • Tom K.
      • February 26, 2008
      • 167
      Check your tail lights. I think they are on the same fuse. That was a way they were designed to warn you that the tail lights didn't work.
      Tom
      • Peter H.
        • April 1, 1980
        • 223
        Edmund the tail lights are on the same circuit..so no dash lights probably tail lights not lit....peter....fuses.
        • Bill L.
          • April 1, 1985
          • 349
          Ed:
          The suggestions by the other folks are excellent and you should check each of them for sure. I would add that the rheostat (in the switch) that controls the dimming of the panel lights sometimes gets corroded. Either the spring and / or the tab can get a build up of rust and / or dirt over the years and cause the panel lamps to not dim or brighten properly or in severe cases to not work at all. See the photo below..... the spring should be clean and shinny as in the photo and the contact area on the under side of the tab contact should be clean and rust free as well.
          Hope this helps a bit.
          Regards
          Bill
          • Edmund C.
            • April 14, 2015
            • 232
            Guys: Thanks very much. Amazingly helpful. Best, Ned
            • Edmund C.
              • April 14, 2015
              • 232
              Guys: Any guidance on where I can purchase a correct fuse (3AG/AGC 4 amp) for the dash lights would be much obliged. Again, thanks for the supurb guidance. NCRS fellowship is the best. Regards, Ned
              • Wayne M.
                • March 1, 1980
                • 6414
                Talking about (Paradise by) the Dashboard Lights, Meatloaf collapsed on stage at a concert in Edmonton Alberta, last week.
                • Leif A.
                  • August 31, 1997
                  • 3607
                  Edmund,
                  If you're talking factory correct with markings and all, Paragon or LIC will have them. A serviceable replacement is available at any parts store closest to you.
                  Leif
                  • Edmund C.
                    • April 14, 2015
                    • 232
                    Many thanks Lief.
