I would like to ask for some help. I recently purchased a 1964 Convertible 116595 with "Fuel Injection" and I am trying to determine if the car is truly an originally equipped L84 car.
Using the Judging Guide, I have established this car was built in April and the trim tag indicates B12 or a Feb body build (AO Smith???). The body build number does not have an "S" or "A" prefix. The trim tag also indicates this car was originally silver with red interior
From pictures I received with the purchase, this car had an under dash fire sometime around 1968-1969. The first owner sold the car to the second owner and the second owner "rebuilt" and showed the car. He repainted the car red and installed a black interior.
The second owner installed a telescoping column and teak steering wheel (which is great for me), but not correct for a 64. The car has 5 knock offs but the dates are not correct. I don't know what else he may have "added" to the car.
The car sat parked in the second owner's garage until be passed on sometime in the 2013-2015 timeframe.
The engine that came with the car is the correct 3782870 RF code engine block with a A284 date code, but the VIN derivative does not match the car.
The Fuel injection unit I received with the car has been professionally rebuilt, but I question if it is original to the car. It appears to be a 1963 unit (two balance tubes). Did early 1964 cars use the 1963 style unit?
What should I be looking for on this car that will tell me about the originality of this car as being a real Fuelie?
