My 67 327, with power glide and stock points ignition system has been causing me issues starting when hot--starts fine cold, but drive it around, shut it off, and turn the key and no click or anything. Cools off and it starts fine. Figured since the solenoid is relatively cheap and available at local auto parts stores, I'd start there.
So yesterday I began. Removed the starter and cleaned up all the wire connectors on the harness. No corrosion, just very greasy. The solenoid on there was a replacement part--done sometime by the owner before me. Put the new one on, that I bought at AutoZone, reinstalled the starter, hooked the battery back up, and then the car has no power at all anywhere. Power windows, headlights, etc...nothing works. And yes, I had the negative terminal of the battery disconnected before I touched anything, and the entire time I was working on the car.
To make matters worse, when I had no power, I disconnected the battery again and rechecked all my connections at the starter, and removed and replaced the main positive (two wires, red and black, tied into one loop connector) connection from the starter solenoid to check that, and when reinstalling it, I cracked the plastic end cap to the starter solenoid, so I'll need to go get a new one and install it. Didn't really want to put the old one back on, just to troubleshoot given how heavy the starter is (I guess I'm a weakling--couldn't lift and hold it in place one handed in order to start a bolt and had to get a helper).
Can someone help me start to trace down my electrical issue if I'm still dead as a doornail with a new solenoid installed. Mine's a late production 67 (build date May 67) and I know it has a fusible link somewhere under the hood--don't know where that is to check it out--could I have blown that somehow?
Battery has juice--beyond that I'm not sure where to troubleshoot and how to do so once I have the new solenoid on. And I'd like to have a game plan mapped out at the ready.
Thanks all.
Thanks all.
