72 Clearance issues - NCRS Discussion Boards
72 Clearance issues
  • Rey S.
    • April 1, 1995
    • 277
    72 Clearance issues
    For those of you that may have been following my clearance issues with the bumper brace/headlight mounting frame. Well---I put a fix upon it. I made up two flat washers (spacers if you will) out of 3/8 aluminum. These moved the bumper brace outboard enough to achieve +/- 1/4" gap --- Problem solved at least for now. But if knew then what I know now I would have just shortened the headlight frame brace a smidge (future time) and that would have taken care of the problem as the HL frame will flex plenty to gain ample gap. I will address bumper alignment when the time comes.
