1969 Dash lightbulb sockets - NCRS Discussion Boards
  • Thomas F.
    • November 11, 2008
    • 204
    I need original dash bulb sockets for my 1969 Corvette. The holes are 5/8" dia. and completely round. The twist in sockets do not work. I need the push in type. All I see advertised for my model and year car are the twist in type. If all 69 Corvettes are like mine these do not work. I have tried to use a certain generic socket I purchased at a local auto store, but they pop out too easily. Any help would be appreciated.
    • 3415
    Re: 1969 Dash lightbulb sockets
    Hi Thomas,
    Have you looked at Corvette Central #661073?
    It looks to be what you need.
    • Thomas F.
      • November 11, 2008
      • 204
      Thanks Alan
      These are the type I am currently using and they pop out very easily when I am reinstalling my dash cluster. I was thinking the original sockets were different from these and were smaller. Do you know if these are the same as the originals?
        • 3415
        Hi Tom,
        I really not sure.
        I replaced one socket on my dash harness but I don't remember where I bought it.
        It's has in place fine but I just can't remember it's source.
        Is there any way you could do a slight 'improvement' on the prongs to help keep the socket more securely in place?
        • Thomas F.
          • November 11, 2008
          • 204
          Thanks Alan I appreciate your help. I am ordering some from Corvette Central. They look like the ones I am using. Maybe these are the original types I don't know. Thanks again for the tip.
          • Gary K.
            • August 18, 2010
            • 85
            Tom - like yourself I'm in the dash doing these right now. The Corvette Central #661073 is not like the originals which have more prongs and prongs are shaped differently, straight out not bent/looped like those. Plus the originals I'm using do not come out easily - in fact the little metal prongs want to break off before the socket comes out.
            GK
              • 3415
              Hi Gary,
              Thanks for illuminating/enlightening us!
              2 puns in one sentence?
              • Thomas S.
                • February 7, 2016
                • 603
                Here is an actual manufacturer of miniature lamp sockets used in many equipment and automotive application.
                For back-up, tail, stop, turn signal and cornering. Ground wire. Sockets accept incandescent or LED bulbs with corresponding bases.16AWG (1.0mm2) insulated stranded copper leads, 8" (203mm) long. Replaces: GMC 8909518, International 57121C91, Motorcraft LS-22.
                67 427/400 Lynndale Blue Corvette https://online.flippingbook.com/view/750924569
