I just changed the PS control valve and hoses in my 1969 350/300 to repair a leak. Steering was fine before changing the unit. Now while driving the wheel occasionally jerks in my hand and it feels as if the car is trying to turn. Seems to happen on acceleration, although it also sometimes also seems to happen at constant speed. It's a fairly subtle jerking and at first I though I was imagining it because the steering was a lot lighter with the new control valve.
I adjusted the valve as described in the service manual. I've examined the front steering components and don't see any other issues. The car corners fine and steers fine most of the time.
Could a defective control valve do this? Is it possible that changing the control valve surfaced an issue in the pump or power cylinder? Can I remove the power steering belt and drive the car to see if it eliminates the problem? I think the issue has to be power steering related. Any advice greatly appreciated.
