1963 Battery Cable Routing - NCRS Discussion Boards
  • Rob A.
    • February 8, 2011
    • 135
    Is there a clip or strap that secures the positive battery cable to the battery retainer/shield? In the assembly manual it appears that there is one but the diagram is unclear. I also noted that LIC sells a plastic retainer.
  • Frank D.
    • December 27, 2007
    • 2703
    Re: 1963 Battery Cable Routing
    I used a clip on my May 29th '63. I don't recall there being any deducts for it in regional judging last January...
    • John D.
      • December 1, 1979
      • 5507
      Rob, Yes there is a battery cable retainer or whatever you call it on the battery box. John
      • Joe R.
        • July 31, 1976
        • 4547
        Rob,
        Yes, there is a metal retainer on early 63's and a plastic retainer on later 63 models.
        Don't have a clue what the breakout point would be for the plastic but the plastic is probably accepted. You will need to check the judging manual or check with the 63-64 Team Leader. Number is listed in "The Restorer".
        JR
        • Gary J.
          • April 1, 1980
          • 1229
          We were taking deducts for clip not present at the Regional in Aurbun this year.
          • Rob A.
            • February 8, 2011
            • 135
            Originally posted by Joe Ray (1011)
            Rob,
            JR
            Joe,
            Thanks for the reply. My early '63 FI car has a metal retainer screwed into the battery shield. My late 340HP (June '63 build) car does not have anything. Is there a picture of the plastic retainer and how it is attached available?
            Rob
            • Bob R.
              • June 30, 2002
              • 1595
              I think the black plastic wire harness clips will work and there is a hole in the metal battery shield that holds it to the battery box.
              • Harry S.
                • July 31, 2002
                • 5258
                Correct, use the same black strap that you use on the gas overflow hose.
                • Dan H.
                  • July 31, 1977
                  • 1365
                  Harry, believe ones on the side fender inserted into holes will work. The gas tank has the same transparent strap as on the firewall.
                  1964 Red FI Coupe, DUNTOV '09
                  • Harry S.
                    • July 31, 2002
                    • 5258
                    Doink, yes the 63 Gas hose strap is transparent/white. It changed to black sometime after 64 as I recall. Too much to remember.
                    • Rob A.
                      • February 8, 2011
                      • 135
                      Is there a picture or diagram showing where the strap attaches to the battery shield? There is not a hole in mine. It's a reproduction/replacement battery tray and retaining shield.
                      • Rob A.
                        • February 8, 2011
                        • 135
                        Is this the correct strap and location?
                        • Joe R.
                          • July 31, 1976
                          • 4547
                          Rob,
                          Yep! that's it! Just a plastic strap that's used for the wiring under the hood.
                          Works perfect!
                          JR
                          • Stuart F.
                            • August 31, 1996
                            • 4676
                            Mine is a July 8 build and always had a black plastic strap. I've changed both the hold down and the strap several times in the past 53 years (also the cables). Got to change the battery again when it cools down. Average daily temp is 98 now which is abut too warm for garage work for this old codger. Poor car has to sit and wait it out until then.
                            Stu Fox
                            • Marco H.
                              • March 1, 2002
                              • 218
                              Originally posted by Rob Anderson (52857)
                              Joe,
                              Rob
                              Rob,
                              Could you please post a picture of the metal retainer on the battery shield on your early FI car? I'm familiar with the later used black harness tie, just never paid attention to the metal clip.
                              Marco
