I am measuring a friend's 65 frame to determine the right number of shims for the various body mounts. My first step was to try to level what I think are the primary gaging points. I have drawn arrows on the attached frame drawing from the chassis manual to show what I mean. I have leveled the frame laterally so that the two holes in the frame below the motor mounts (the 16" dimension in the drawing) are level. My next step was to level the frame longitudinally so that the rear gaging holes (which are the trailing are attachment holes) were 1" below the forward gaging holes.
The problem is that the trailing arm attachment holes are not level. One is about 1/4" below the other. Is this within the ordinary tolerances of the frame? When I measured my own 67 frame years ago I thought that all four gaging holes were very close to level. Hopefully this amount of frame twist is inconsequential, and I am hoping to get some informed opinions on the matter.
