Trying to figure out which plastic bushing is correct.
1963 carb linkage bushing
Re: 1963 carb linkage bushing
Bob -
The top right bushing (larger diameter, to accommodate the black rubber grommet for the throttle rod at the carburetor throttle lever) is correct, and the flange on the bushing goes on the same side of the rubber grommet as the spring end or cotter pin that retains the carburetor throttle rod to the lever, as shown in the Assembly Manual.- Top
This is another current thread regarding the same bushing...just for different years. Was there a change??
https://www.forums.ncrs.org/showthre...ing-gm-3707713.Leif
Top Flight 2017 Lone Star Regional- Top
Leif,
The wide bushing was sold in the 70's as a replacement for the earlier narrow base bushing. The narrow original bushing was used on both ends of the accelerator rod for 63-67. Don't know about later C-3's.
JR- Top
That's what I thought, Joe. Thanks for clarifying. The wider rimmed bushing seems to make more sense, as John described...but, I had seemed to remember that the narrow base one was correct.Leif
