The original carb on my 67 S/B (Holley 3810) is leaking at the four plugs on the float bowls. I've used my dremmel tool to make a V around the circular joint, cleaned them and swabbed them with lacquer thinner in preparation for a tiny bead of JB WELD. However, before going any further I wanted to ask the brotherhood if there's a better product that the JB WELD for this fix which I should use. In my experience JB Weld does hold for a long while, but after some time in constant contact with fuel it begins to soften, loses its grip and then begins to leak/seep.
I'm eager to read your comments and recommendations.
Thanks in advance for whatever help you can proffer.
Ric
Ric
