Hello all
New to NCRS, just picked up pretty decent ’70 LT1, have trivia and several restoration related questions…
1) Have authentic VIN+engine code stamp on block which reflects CTV. Had one experienced Vette judge physically review car while another judge compared my engine code photo with actual ’70 ZR1 (just happened to be in his shop that day…lucky fella), both confirmed authenticity. While my car is not ZR1 for some reason (this is where I need your wisdom), this factory build ended up with CTV motor. Reviewed registry and noted 2 or 3 similar events, so was this simply one of those non-documented options during this year run? And how does this impact value?
Pulled off Internet from 1970 Corvette “CTV” blog response (written by ’70 ZR1 owner):
“The LT1/ZR1 Engine WAS a different assembly than the standard LT1 - Hence the different suffix codes assigned to call-out the non-standard parts required. Although the internals, intake and exhaust were identical to standard version LT1, the CTV suffix code in '70 (and the CGY in '71 and CKZ in '72) were fitted with a 10.5" light weight L88-style flywheel and corresponding 403 bell housingas well as a High-torque L88 ('69 coded & dated) starter with aluminum nose. Some say the ZR1's used a cast-iron balancer pulley, but I've only been able to report stamped units.”
2) My drivers and passengers side door moldings need replacement (top/rear portion); suggestions where I can purchase?
3) Distributor cover appears to be original, wondering if cover supposed to have all those wing-nuts (have seen photos withother versions) and where can one pick up authentic replacement distributorcover hardware?
4) Drivers side seat belt has end piece missing and has been cut, need refurbishment, suggestions?
5) Passenger side rear light cover has small cracks, looking to replace, suggestions?
6) Driver’s side door cover has 2 cracks back where drivers elbow would rest, suggestions for refurbishment?
History: Pink Slip CA title, then NV, no rust, no hits/dings/damage, 26,200 miles, all parts appear to be original, CTV, 4:11, AM/FM
Submitted my info to 1970 registry this AM; Juliet and team have done amazing job keeping that dbase up!
Really appreciate any/all feedback, going forth with authenticity in mind, and of course some 105 octane
Thank you!
Harry
Thank you!
Harry
