53 - 53 powerglide output shaft - NCRS Discussion Boards
  • Edward M.
    • November 1, 1985
    • 1916
    Can anyone show (hopefully with pictures) what is unique about 53-54 Corvette powerglide output shafts?
    Is anyone reproducing these?
    I am having trouble figuring out why this would be so hard to replicate, probably because I don't know what it really looks like.
    Isn't this just a steel shaft with various machining work at select points on the shaft?
    Also, I read something about an "extension shaft", which I guess is some way to extend the length of the passenger car shaft so it will work in a Corvette. Any pictures / info on that as well?
  • Eric F.
    • June 30, 2003
    • 319
    Re: 53 - 53 powerglide output shaft
    The tail shaft housing is longer and specific to corvette. The tail shaft is longer too and has 16 splines. I'm told they are reproduced but I don't know who does it. There are several corvette suppliers carrying the tail shaft but I haven't seen the tail shaft housing in a while. I saw the last one on ebay about a year ago. I've attached a photo showing the part number casting for the corvette tail shaft housing and a photo of a restored 54 corvette powerglide. I hope this helps. Eric
    (P.S. Grossmulers has a tail shaft for sale and show a photo of it.)
    • Edward M.
      • November 1, 1985
      • 1916
      I can't seem to get Grossmueller's catalog. All I get is the first 26 pages, which is the index. Is the entire catalog available online? Would really like to see the tail shaft.
      • Eric F.
        • June 30, 2003
        • 319
        I sent you a PM with a link to the tail shaft.
        • John S.
          • July 29, 2009
          • 640
          26 pages is the entire 53-55 catalog. I do not see the part listed separately in the catalog. it is not called a tail shaft by the vendors, it is a slip yoke. there are a few vendors selling the longer yoke on ebay. an original yoke is easy to spot on a car because the word "spicer" is stamped into the yoke.
          • Edward M.
            • November 1, 1985
            • 1916
            I am not talking about the slip yoke. I am talking about the output shaft that comes out of the back of the transmission. This is the shaft that the slip yoke slides onto. Grossmeullers lists a "powerglide conversion kit" which apparently has all of the parts needed to turn a 53-54 passenger car powerglide into a Corvette powerglide. One of those parts is the transmission output shaft, along with the tail housing.
            • Eric F.
              • June 30, 2003
              • 319
              Ed,
              My mistake, you indicated tail shaft and I thought slip yoke (even though I too indicated tail shaft). Must be one of my early senior moments, sorry to waste your time.
              I suspect they are hard to find because of the limited numbers produced for the 53-55 6 cyl cars. I've had to make several parts for the 54 I'm restoring because they weren't available. The tail shaft be reproduced but I'm not certain. I will check with a few of my sources and get back to you.
              Again, sorry for the misinformation.
              Eric
              • Eric F.
                • June 30, 2003
                • 319
                Hi Ed,
                I couldn't find any suppliers in the area for the shaft or housing. I see them occasionally on ebay but is been a while. John Amgwert wrote an article in the Corvette Restorer years ago that will answer your questions and offer some insight into options for acquiring the unique output shaft and housing. I don't know the exact year of the article. I purchased the 53-55 archive disc and found it in the transmission section. I can't post the article but I will post the heading and the first paragraph where I agree with John, as I'm sure you'll agree.
                Also, here's a link to the DVD in the store. I hope this helps.
                Eric
                • Edward M.
                  • November 1, 1985
                  • 1916
                  Originally posted by Eric Falk (40085)
                  Hi Ed,
                  Eric
                  Anyone know what issue of The Restorer this article was in?
