Wiring a new engine harness today, I removed the motor brackets to fish the harness above and in front of the motors. What do you think happened? Besides hearing a loud expletive when I discovered it.
Hints....Views from inside engine bay looking forward. This is a red car.
Driver side
Pass side
This will also cause another malfunction. It's observed from the driver seat when the lights go on and up. Hint, the prior harness wasn't connected to the telltale switches.
If you give up, scroll down and find the reason and see what it should look like......
When I loosened the motor brackets from the header reinforcements, both buckets rotated from the weight of the motors and tried to open partially. I was stumped at first, then it hit me......
It has it's inner bucket pivot housings reversed. As you can see, the rods for the motor capture bracket are in the opposite location, facing forward. They should face rearward for the motor bracket to capture it. If the wires were connected for the dash Telltale LIGHTS lamp, it would work in reverse, meaning when the lights are on and buckets raised completely, the LIGHTS lamp will light up. With the buckets down, the lamp would go off. This car has been like this for at least 16 years. Now everything has to come apart to make it right.
Black car, correctly mounted. The inner pivot housings are seen best in the first 2 photos.
Rich
Driver side
Pass side
Rich
He's not to far from me. We've spent hours on the phone having fun stories to share.
