63 327/300 Overheating - NCRS Discussion Boards
  • Don H.
    Moderator
    • June 16, 2009
    • 2236
    Re: 63 327/300 Overheating
    Joe is right, as usual, and you also have an FI type radiator core support with the big hole to left of radiator for FI air cleaner air intake.
    Much air that should pass through your radiator is going through that hole instead. You should make up a cover to block that hole.
    Do that, replace your radiator with aluminum and replace your fan clutch and you should be running cool as a cucumber.
    • Leif A.
      • August 31, 1997
      • 3607
      And, while you're at it...add this little gem that was factory installed on A/C equipped cars. It will help keep incoming air going THRU the radiator instead of over it.
      Web catalog of 700+ pages, 1000+ illustrations, 12,000+ Corvette restoration parts available mail order. Dr Rebuild Corvette Products manufacturing & distributing parts for 1953-1982 models for 22 years.
      Leif
      • Joe C.
        • August 31, 1999
        • 4598
        #18
        Which "Joe"?
        I think if he goes by what I said in post #5, he might find that he doesn't need a new fan clutch.
        • Bob W.
          • December 1, 1977
          • 799
          #19
          Leif Does the Dr rebuild air dam just snap in place and do you use one?
          • Ralph E.
            • February 1, 2002
            • 905
            #20
            David, Replace the radiator. The fan does nothing at highway speed. Your radiator is shot. Get a new Dewitts Radiator and your problems should be solved.
            • Frank D.
              • December 27, 2007
              • 2703
              #21
              Not to hijack but it looks like there are clips to install the air dam.
              Anybody have a picture of the dam installed - never seen one ?
              • Leif A.
                • August 31, 1997
                • 3607
                #22
                Bob,
                There are four clips that hold it in place. Don't recall if Doc's piece comes with them or not. They're available from Paragon or LIC or maybe even the Doc...and, yes, I absolutely have one on my A/C car.
                Leif
                • Leif A.
                  • August 31, 1997
                  • 3607
                  #23
                  Frank,
                  Hope you can see the clips in this pic...I used six of them (bit of overkill) factory called for four.
                  Leif
                  • Bob W.
                    • December 1, 1977
                    • 799
                    #24
                    Leif I buy most of my parts from Paragon . They also sell it, $32.00 with 4 clips. Please post a picture of your car if you have time
                    Bob
                    Thanks for the help
                    • Leif A.
                      • August 31, 1997
                      • 3607
                      #25
                      See post #23
                      Leif
                      • Bob W.
                        • December 1, 1977
                        • 799
                        #26
                        Leif Thanks for the picture I didn't see it when I posted .
                        Thanks again Bob
                        • Frank D.
                          • December 27, 2007
                          • 2703
                          #27
                          Originally posted by Leif Anderson (29632)
                          Frank,
                          Perfect - yes Dr. Rebuild sells the clips and says 4 or 6 were used. I didn't notice this piece on the '63 coupe factory air car judged at Lakeland last January and wondered about it - apparently it can be used on 63s but the piece only entered production '64 and up (or that's what I read anyway)..
                          • Joe C.
                            • August 31, 1999
                            • 4598
                            #28
                            1966 and up. Nothing used before then.
                            • Ralph E.
                              • February 1, 2002
                              • 905
                              #29
                              To David Fallon,
                              Just curious, did you ever resolve your overheating problem?
                              Your solution may help others.
                              • David F.
                                • January 10, 2011
                                • 48
                                #30
                                Update on my overheating: I plan to replace the copper radiator with new aluminum one (Dewitt). But I have done nothing because of the excessive heat index around North Jersey this past week. Also I will be in Carlisle, PA this Thursday and Friday (8/25-26/2016) with my shopping list.
                                David
