I have what I believe to be the original shroud on my 63. It has a total of 7 welded cage nuts, 3 for each side and one on the top center. The one on the car has a large dent so I wanted to replace it.
I found a "NOS" online but it dose not have the welded cage nut on the top center. It does have a slotted hole that would allow for adjustment. It does look legit with no signs of a broken weld from a nut that may have come off.
It was listed as 1963 1964 1965 Corvette NOS 3829723
The AIM for 63 shows separate part number which end up getting spot welded to form the shroud.
3824487 Lower, 3824489-90 Left and Right, 3824486 upper
I think its unlikely that individual pieces would have been sold for repair so would the above NOS be judge as correct?
