I will be getting my 66 coupe back from paint next week. I've been thinking about the best sequence for installing all the stuff in and around the dash.
As I recall when I took it apart (no I didn't take enough pictures), the wiring harness goes above all the other stuff, e.g. pedal assembly and park brake handle assembly, so I need to string the harness across under dash before these go in.
Any advice on the following sequence from experience appreciated.
Dash pads
Wiring harness
Gauge cluster (suspended with long 1/4-20 bolts to aid wiring to harness)
Steering column
Hood release
Pedal assembly
Park brake handle assembly (with V74 flasher)
Speaker grille
Speaker
Radio
Radio side panels with antenna switch
Glove box
Shifter surround/console
Dash pads
Wiring harness
Steering column
Hood release
Pedal assembly
Speaker grille
Speaker
Radio
Glove box
ps I haven't forgotten the column write-up. I'll get to it soon.
