Trying to dry up an oil leak at the front of the engine on my 59 I decided to remove the pan and change the gaskets. After removing the pan I discovered a considerable amount of hardened sealer on the pan lip. I removed the sealer and laid the new gasket on the pan for a trail fit (using a 1 piece OS34509T) and the portion of the gasket that goes between the timing chain cover and pan swings freely not touching the pan lip.
I took my pan over to a friend who has some original 3 step pans in his garage and did a comparison. My pan is clearly a reproduction (the engine had just been rebuilt when I bought the car so I don't know the story behind this pan). The main difference in the front of the pan is that the radius of my pan is approximately 3/16" greater than an original.
I have located a used original that I will clean up and install but I would really like to know what this pan would fit. It is a 3 step with the trap door. The only marking I can see is "220R" stamped in the center step. The entire pan, inside and out, has been powder coated black before the outside was painted Chevy orange.
Is there a SB that uses a larger timing chain cover? If anyone has any ideas I would appreciate knowing what I have.
Sully
Sully
