I am curious about how the C2 underbody was built, and then how the upper body and other pieces were attached to it. I have Mueller's book on Corvette factories, which has a couple of pictures and a brief description, just wondering if anyone knows of a source with more detailed info and pictures. Thanks.
C2 body manufacture process, underbody and upper body
Big Tanks In the High Mountains of New MexicoTags: None- Top
Re: C2 body manufacture process, underbody and upper body
John Hinckley (JohnZ) put together an excellent presentation with photos on the C2 manufacturing process and presented it at the NCRS Nationals a few years back. I believe it is available on the NCRS Michigan Chapter website or perhaps in this website archives.I am curious about how the C2 underbody was built, and then how the upper body and other pieces were attached to it. I have Mueller's book on Corvette factories, which has a couple of pictures and a brief description, just wondering if anyone knows of a source with more detailed info and pictures. Thanks.
If all else fails, send me a PM and I will send you the file. I believe there were a few hundred photos as well as commentary.
Larry
EDIT: Just checked for you, and all four parts of the presentation are still available at NCRS Michigan Chapter website under "DOWNLOADS" Section on the header bar. About 40 MB total size. Larry- Top
Thanks guys, this all will do me. Just trying to visualize what all was happening in the body shop as everything was coming together and in what order, this helps a ton. Thanks again.Big Tanks In the High Mountains of New Mexico- Top
Mike,
The Licastro book is very interesting with a plant "map" (diagram) depicting plant layout at StLouis. Pretty good narrative on the process. Ties into the excellent John Hinckley presentation mentioned in #3 above.
Dave
Birthplace of Legends: The Story of Corvette Production at the St. Louis Assembly Plant, 1953-1981, Paperback– July, 1993 by Peter LicastroJudging Chairman Mid-Way USA (Kansas) Chapter- Top
Thanks David, I'll check that out.Big Tanks In the High Mountains of New Mexico- Top
