I'm installing a 350ci in my 1962 vette and need to come up with a PCV system(I think). I want to keep Corvette valve covers and leave the engine looking as stock as possible. My original thought was to use a little newer Corvette valve cover with PCV port and draw the vacuum thru the back of the stock carburetor. The stock oil filler tube would vent the engine from the front of the engine. Here's the problem: I'm using roller rockers and that doesn't allow room inside a stock valve cover for the oil separator at the PCV valve port. Should I abandon the PCV system and just vent each of the valve covers or do you guys have some clever solution?
PCV system
Re: PCV system
Phil,
Can you use the filler tube on the intake manifold for the PCV and the valve cover to vent (intake) air back to the motor. If you nix the roller rockers and use the stock baffles for both ends of the system that would be best. I would be careful which oil pump you use.- Top
Re: PCV system
Duke- Top
Re: PCV system
You didn't say what your objective is, but the LT-1 cam with massaged heads will make close to 300 SAE corrected RWHP (close to 350 SAE net at the crank) depending on induction and exhaust system and useable power to close to 7000 in a 350 with decent low end torque and enough "attitude" at idle to tell everyone it's a highly tuned engine. A 3.75" stroke crank configuration is even better.
The best induction system is either FI or the LT-1 manifold with a 750 CFM vacuum secondary carb. The best exhaust system is 2.5" manifolds and 2.5" pipes all the way back with low restriction mufflers.
Duke- Top
Re: PCV system
Phil-------
I highly recommend the use of hydraulic roller cams, especially in this day-and-age. Most OEM OHV applications have used hydraulic roller cams for more than 25 years now. For Corvettes it's been 30 years. However, it is possible that you have too wild of a grind. I'd recommend a roller grind that approximates the flat tappet L-46/L-82 cam.
As far as roller rockers go, there are some available that will work with the oil control baffles built into 1969+ style Corvette valve covers. The 1996 LT-4 style rockers are an example. These are an aluminum roller rocker and are not the type that I personally favor but they should work with 69+ valve covers. The LT-4 rockers were a PRODUCTION-validated piece so that should offer some measure of confidence.
As far as the manifold/carburetor situation goes, hood clearance can be a problem with the LT-1/Holley set-up. I was not aware it was a problem for C1 Corvettes but, from what you report, apparently it is. This surprises me in a way. The 1962 340HP manifold was a fairly high riser design although it did use a Carter AFB carburetor. However, it was virtually identical with the 1964 L-76 manifold which did use a Holley carburetor. So, at the worst, I would think you could use one of these manifolds with the Holley carb. Or, you might be able to use one of the 1965-67 small block cast iron manifolds for Holley carbs. I don't know of any low riser GM aluminum small block manifolds.In Appreciation of John Hinckley- Top
Re: PCV system
Are you sure? I don't mean to argue with you because I'm not sure. But I had a late 60's Z-28 intake manifold and an 1850 Holley carb with a drop down base open air cleaner under the hood of my '62. It was close. But it fit. The drop down base air cleaner also came from a Z-28. Not sure, but I believe the late 60's Z-28 parts were the same as the LT-1.- Top
