I have the engine mostly apart (crank and cam still in). It has not run in over 30 years, but I rebuilt it a few years earlier.
Bores, checked with a dial bore gauge, vary between 4.001 and 4.003 in either direction (no individual bore varies by more than .001 with respect to taper, most by .001 with respect to out of round, none over .003). These numbers are calculated by the maximum - the minimum dimension, accounting for taper.
The pistons, Chev P/N 3959460 measure 3.998 (I confess to measuring only 2) in dia, perpendicular to wrist pin, in middle of the skirt.
The bores look remarkably good, the cross-hatch from honing still shows.
I'd rather not bore and replace the pistons. Comments?
Thank you!
Thank you!
