Actually, they haven't been all that bad for a few years, but after 14 years of ownership that started with a car on the verge of overheating if it was driven more than five miles, we are today at a place where it runs at 180 degrees all day long in 80-90 degree weather.
The final item is the upper radiator seal available from Doc Rebuild. I THINK this seal is for AC cars but since my car had nothing up there, it made at least a 10 degree difference.
Over the years I have done the following, all because of the knowledge gained here:
DeWitts Radiator ( BIG HELP). The car had a copper radiator when I bought it and it was in bad shape
Proper Vacuum can and timing (per Duke's two inch rule) Thanks Duke!
New fan clutch from J&R
Upper radiator seal. Surprised at the difference this made.
After I installed the radiator the car was drivable but I had to avoid traffic jams on hot days. All the other changes made incremental but noticeable improvements.
So, I guess the moral of the story is, if you make it like The General did when it was new, it should work like it did when it was new.
Thanks for all the tips over the years
Rich
Rich
