The Corvette Service manual (Book 2) Reminds you to properly secure the radiator air deflector to avoid water intrusion into the engine. This is completed prior to installing the air cleaner assembly. I see no info in the service book Can some one elaborate on this issue?
1993 Air Cleaner Assembly
Re: 1993 Air Cleaner Assembly
I believe they are talking about the plastic sheeting that goes in the bottom before the air filter box goes in.
Attached Files- Top
If your missing it here's one I found on eBay.
- Top
Here is the page from the parts books. Item 1 part number 10204532.
Item 49 in pic is a push in retainer #20032850.Attached Files- Top
Here this should fit.
- Top
My 90 has no retainer its just sits below the air filter housing inside the engine compartment. I can't find any illustration or pics on how yours would go in. Maybe some one here with a newer C4 could provide some pics.- Top
