Re: 69 L71 will not fire off
Rich,
See my reply below:
Background.....The PU coil generates a very small pulsed DC voltage to trigger the TI Amp module at each rotation of the 8 distributor poles/plug wire positions. The voltage is around 2 volts. It is VERY important that the polarity of the 2 distributor PU coil lead wires to the harness is correct. Since you've had to replace some wires, it is possible someone else before you had the connectors apart, and reversed them, or maybe you did accidentally. I CHECKED POLARITY AND IT IS CORRECT. I EVEN SWITCHED THEM NO SPARK. I SWITCHED BACK TO CORRECT POLARITY.
Additionally, certain TI module circuit board designs may be more sensitive to these low input voltages. It has not been determined which of the 3 types of boards are in your system, original Delco, M&H reproduction, or K&B reproduction. You would have to open the AMP Module case to verify. Internal module grounds to the circuit board of course are important as well. You may have to open it up to verify at some point. I HAVE NOT OPENED UP THE AMP YET.
I would check the following:
The PU coil WHITE wire connects to the harness PINK wire. This is the source power to both the PU coil AND the TI Module.
The PU coil WHITE/GREEN (or if PU was OTC replaced, the GREEN wire) connects to the harness GRAY wire. This is the PU coil output wire which is the trigger wire to the TI Amp.
If these 2 wires are reversed, it can cause intermittent/weak trigger pulses to the Amp. You may have to remove the dist cap and carefully trace the wire colors inside at the PU coil wire pair down to your repaired external connector OOPS FORGOT TO DO THIS.
If those appear correct......
At crank, the PU coil pulses are of short duration, therefore a higher voltage is required at crank as the battery supply is being reduced by the starter motor current draw. This much like a Ballast resistor bypass in a points ignition system at crank. The harness includes a small gauge PINK wire which directs full battery voltage to power the AMP AND PU coil input. This higher voltage is needed to ensure proper supply voltage at crank.
The PINK wire source is the Starter Solenoid "R" terminal. In the engine/forward harness, there is a single plastic plug wire terminal from the solenoid R which connect to the associated TI Harness plug, likely running along the upper hood ledge area. Visually check that is there and verify proper voltage at crank, below. FOUND THIS PLUG AND IT IS SNUG
Connect your - meter lead to ground, + meter lead to the distributor PU coil WHITE/ TI Harness PINK wire. Turn IGN ON, no crank. You will see a reduced battery voltage on the meter as there is a resistor wire in the harness to drop voltage to the AMP. Record voltage reading. 7.68 VOLTS WITH IGNITION ON AND NO CRANK.
Then while observing the meter, crank the engine and record voltage. It should be higher than previous reading, at or near full battery voltage during crank. As a reference, you can record the battery voltage at the +cable during crank also. DURING CRANK THE VOLTAGE DROPS TO 3.9 VOLTS. BATTERY VOLTAGE IS 12.13
SINCE THE VOLTAGE DURING CRANK IS VERY LOW WHERE SHOULD I FOCUS MY ATTENTION?
Thanks very much,
Lawrence
There of course are other possibilities causing your weak spark. These are just a few to try, but should be verified to help diagnose the fault.
Rich,
See my reply below:
Thanks very much,
Lawrence
ONCE MOVED I WAS GOING TO PULL THE DISTRIBUTOR AND FIX FOR LONGEVITY.
WILL LET YOU ALL KNOW WHAT I FIND.
