I am working on the above car with TI ignition. The car ran fine and last week when I tried to move it in the garage it just would not fire off. The car turns over, getting gas, but will not fire. Acts like it is not getting any spark. I went to check the wire connection at the distributor and the wires broke off at the connector. The wires are short at the distributor I connected longer wires so I would have room to connect back to the harness. While connecting the wires I noticed that the wires coming from the distributor are silver and the wires (which I used from an old 67 harness) are cooper? I guess this is fine? I have connected everything back up and expected the car to start. Still nothing. I am not getting any spark it appears. This is my first C3 more familiar with the C2's. Any idea why I suddenly would not be getting any spark? By way of background this car is unrestored had been sitting in Ca for some years. it had several loose connections when I got it which I simply fixed and things started working. I am thinking perhaps there is a loose connection somewhere in the harness that is causing this grief? Any ideas?
Lawrence
Lawrence
