What motor oil(s) do you have most overall confidence in that contain zinc and other components designed for c-2 engines. I have been using Brad Penn but am concerned it is a partial synthetic. I don't want to add an additive to the oil. Thanks! Michael Kalogridis
Oil for 327
Tags: None
- Top
Re: Oil for 327
i too use rotella. get it in gallon jugs at local tractor supply when its on sale, leaving more change for the beast.inthe past, esso had a high zinc oil for diesel engines that i always used till its availability went down the tubes. mike- Top
Re: Oil for 327
Those are good oils, I have also been using Valvoline Racing VR1 20W-50, it also has high ZDDP content and is about $5/quart.Big Tanks In the High Mountains of New Mexico- Top
Re: Oil for 327
Michael,
That question has been asked by many before you and there has been a great deal said (written) on this subject - and much of it is in forum archives - a lot of good stuff. Allow me to save you some research time - I am attaching two pdf files that should answer all your questions. One article is written by Duke Williams (great article) , the other is a Motor Oil grading guide that will enhance your understanding of oil in general.
By the way - filters - also discussed a in great length in previous threads; I think you will find that the consensus of members that have been around for a long time advise against using AC 141 reproduction filters. Instead they recommend using a WIX brand filter, # 51143, same filter available from NAPA, their # is 114. Among other things the "cans" on these filters is metal instead of paper like the AC repros.Ed- Top
Re: Oil for 327
Remember when using older threads that things keep changing now days. I have been told that diesel oils which up until recently have the needed ZDDP, but that it is being fazed out of this oil also. I have not researched this so I don't know if it is so or not. My intent here is only to say keep up on these oils when ever you buy more.- Top
Re: Oil for 327
As I understand, the NAPA "is" the WIX filter, with a NAPA pn. Notice the PN contains the same # 114. When I purchased one at a NAPA store I asked the sales clerk and he stated that their parts book indicated that the manufacturer was WIX.Ed- Top
Re: Oil for 327
Russ,Remember when using older threads that things keep changing now days. I have been told that diesel oils which up until recently have the needed ZDDP, but that it is being fazed out of this oil also. I have not researched this so I don't know if it is so or not. My intent here is only to say keep up on these oils when ever you buy more.
I think that may be a myth that has already been debunked. As long as the bottle says API CJ-4 or CI-4, everything is cool from a ZDDP standpoint. But you are right, it pays to stay up on things in case something changes!
Joe- Top
Re: Oil for 327
Who told you that?Remember when using older threads that things keep changing now days. I have been told that diesel oils which up until recently have the needed ZDDP, but that it is being fazed out of this oil also. I have not researched this so I don't know if it is so or not. My intent here is only to say keep up on these oils when ever you buy more.
Duke- Top
Re: Oil for 327
NAPA Gold #1143. Made by WIX in the USA. Very high quality..................better than most (or all) others on the market. I know Duke likes Baldwin filters, and I am sure they are also very high quality. I don't have their part number handy, but it should be easy to find.
Larry- Top
Re: Oil for 327
I derived this Baldwin filter # from a previous thread. You can use either aBaldwin P18 or P18HD. I could not find Baldwin filters in my area, went with NAPA (aka) WIX.NAPA Gold #1143. Made by WIX in the USA. Very high quality..................better than most (or all) others on the market. I know Duke likes Baldwin filters, and I am sure they are also very high quality. I don't have their part number handy, but it should be easy to find.
Larry
And while we are on the subject of filters - Air Filters; Paper filter for a 64 L76 is the WIX 42070. NAPA # for the exact same filter is 2070, about $9.00 but.... if it is not stocked in your local NAPA store (and probably isn't) then they will charge you a shipping fee from the warehouse - another $8 or $9.Ed- Top
Re: Oil for 327
Thank you all so very much for taking the time to post information. I really appreciate it.
Michael Kalogridis
And while we are on the subject of filters - Air Filters; Paper filter for a 64 L76 is the WIX 42070. NAPA # for the exact same filter is 2070, about $9.00 but.... if it is not stocked in your local NAPA store (and probably isn't) then they will charge you a shipping fee from the warehouse - another $8 or $9.- Top
Dr. George
