Seat Belt Cables replacement on 65' roadster - procedure ? - NCRS Discussion Boards
  • David K.
    • September 30, 1992
    • 281
  • Scott P.
    • April 30, 1992
    • 178
    Re: Seat Belt Cables replacement on 65' roadster - procedure ?
    David, you should be able to access the nut that's on the cable stud by lifting the carpet in the seatbelt attachment corner. The belt will not need to come out. Look in your AIM. Scott
    • David K.
      • 281
      Thank you Scott ! Hope all is well with you. Bad health kept me from taking the car out of the garage between April thru July. Just got it out the last few weeks ! Catching up on maintenance etc...
      Keep well; David
