It is my understanding that there should be voltage to both leads going to the terminals of the ammeter gauge. I have voltage to the blk lead but not the blk and white lead. I do however have voltage at the horn relay on the blk and white lead. Where should I start to find the break?
C2 Ammeter not working
Re: C2 Ammeter not working
The connectors are down low outboard of the clutch push rod.
Pull these connectors CAREFULLY and examine them for green corrosion, bent/pushed-in pins etc...
Be careful you don't break off the hard plastic "tabs" on the firewall-side plugs that secure the connectors - that's no fun at all.Attached Files- Top
I have the same problem "C2 ammeter does not function". Have never removed my bulkhead connectors. Will attempt today,
Question for Frank or others that have successfully removed them. Do the connectors on the engine side of the firewall come straight out? Are there tabs that have to be squeezed to release them as pulling force is applied? If they are tight I assume it is not wise to slightly wiggle them left to right - correct?. Essentially, I am asking, how are they removed without doing damage to them or the other side?Ed- Top
Biggest issue is probably brittle wiring at the plugs, or brittle plastic connectors/clips. Probably okay right now, but if done during winter time, use a hair dryer to warm things up.
Many pictures abound of the connectors if you search here or google for information.
Larry- Top
Larry - thanks!
I did a quick search for threads on "bulkhead connectors" - found a number of them, one in particular was great, it included a close up pic of the connectors and additional advice from Joe Lucia on how to clean them. Here is the link to the thread.
https://www.forums.ncrs.org/showthre...head+connectorEd- Top
I had the same problem, The link below is to that thread. after you get the under hood harness disconnected from the firewall. Clean the terminals, I used a small wire brush and dremel tool with wire brushes. Then clean it again, and maybe again. Then carefully take a small screwdriver or pick and spread the connectors.
That was my problem and my meter works fine now.
https://www.forums.ncrs.org/showthre...topped-workingDon Harris
Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)- Top
