It has been a number of years since I changed out the battery in my 63 L-76. I know I must move the recovery tank out of the way, but is it adequate to just disconnect the "T" from the heater hose to move it far enough? I really don't want to disconnect the heater hose from the heater core nipple as those spring clamps don't work all that well to make a leak proof re-connection. Last time I did that I had to use a worm clamp to get it to seal, then after a period of time, I opened the worm clamp to remove it and slid the spring clamp back up the hose into position over the nipple.
Stu Fox
Stu Fox
